This isn't a big problem just an annoyance. Looking for suggestions. I have a 1988 basstracker 17 ft. It has the two casting platforms front and rear and a steering wheel console. Problem I have is a weight problem. The boat only has a 40 hp mercury on it. In the back of the boat I have Two 1000 amp batteries biggest I could find for trolling and starting. Two 6 gallon gas tanks.The batteries are on the right side just behind me. When I sit in boat the left side of boat sits low in water from all the weight on right side. I weigh about 200 lbs . I want to move batteries to other side or maybe move one under front casting platform if I can get battery thru that small door under deck. The reason I want to do this is boat is taking on water when I take corners. Anyone ever do this and any ideas would be appreciated.
