Can't understand what has happened here... Motor has been making "grinding" noise when rotating back and forth (like sand in the bearings). I gained access so I could see both bearing assemblies and I noticed that the shaft has a wear groove in it (below where the bearings sit)? Perhaps I need to cut the shaft down a few inches, redirll and remove the worn section. Could put in a new set of top and bottom bearings... Still - I can't figure out why it's wearing the way it is? Perhaps if I pull everything out, I can see what's causing it??? Anyone had similar issue(s)???
