Mguill4650
- Apr 4, 2015
- 4
I am restoring 1935 Dodge runabout and will be replacing the original engine with a Mercruiser 140 - serial number 0A432326/ 1985 - setup as an inboard. I would like to use the original mechanical tachometer. Is it possible to convert the Mercruiser electrical connections to run a mechanical tach? Distributor conversion kit?
Thanks
Thanks
