Actually what it says is:<br /><br />"Solder shall not be the sole means of mechanical connection in any circuit.11.16.3.7.<br /><br />and then<br /><br />"Solderless crimp on connectors shall be attached with the type of crimping tools designed for the connector used, and that will produce a connection meeting the requirements of E-11.16.3.3. 11.16.3.8.<br /><br />"Terminal connectors shall be the ring or captive spade types. 11.16.3.4.<br /><br />"Twist on connectors, i.e., wire nuts, shall not be used. 11.16.3.6.<br /><br />"Ring and captive spade type terminal connectors shall be the same nominal size as the stud. 11.16.4.1.12.<br /><br />And then you have people like Don Casey <br /> http://www.boatus.com/boattech/casey/05.htm
