I have a 2 bank charger and I want to run my batteries in parallel but have a question about charging them using both banks. If the batteries are hooked up parallel, can I use a bank per battery while they are connected in parallel. Or do I need to disconnect the parallel connection before I charge them. If I have to disconnect before charging would it make more sence to buy a A/B/Both switch?
