rpm meter
flortje
help me <br />i fryt my lcd digitall omc rpm meter i need diagram or print foto from the component's to recognice resistand collor en replace it <br /><br />thanks<br />didier.dutrieux@pandora.be
gaugeguy
Re: rpm meter
If you fried it, unless you are an electronics engineer, a print is not going to help you. Those digital tachs have surface mount components that you won't be able to tell a capacitor from a resistor. A replacement tach sounds like the order of the day.
flortje
Re: rpm meter
i now about electronic en this is posibel to repair if have wiering diagram or foto from print whit components on it
gaugeguy
Re: rpm meter
I'm not sure who makes the OMC digital tach, possibly Aetna Engineering. It's going to be hard to get a print of the inner workings of that tach though. Good luck.
