Re: battery problem
2 6v battery systems have been dicussed here, use search to locate.<br /><br />How long are you trying to run your motor? Hours? Days?<br /><br />Make sure you are using a deep cycle marine battery.<br />What is the amp hour rating on the battery?<br />How many reserve minutes?<br />Proper fluid level?<br />Fully charged when you start to use it?<br />Have it load charged at Walmart or auto service center. You could have a bad cell.<br />Double check your trolling motor that it is a 12v unit. Or that it is hooked up properly if it is a 12/24v unit.<br /><br />You should be able to run 8-10 hours with the right battery, unless you are fighting river current all day or running wide open for hours.<br /><br />If all else fails, you can run 2 12v batteries. This will increase your troll time by about 2.5 times.
