I've already replaced my transducer with a new one but, for your info and reading pleasure here's what they say.....<br /><br />Transducer Cable Splicing Instructions. <br />Lowrance does not recommend cutting and slicing of transducer cables. The connector ends are injection molded onto the cables and the transducer body housings are potted with an epoxy material to make this accessory completely waterproof. Water infiltration in this cable can cause delaminating, internal corrosion, and cable damage, which can result in poor performance at the least - and sounder malfunction or damage at the worst. If a cable is cut or broken we do provide some accessory connectors which are preferable to splicing if the cable remains long enough to reach. However if the cable is too short or a connector kit does not exist then you should follow these instruction to splice the cable. This procedure is best performed by a reputable and skilled electronics repair facility or technician. <br /><br />Cut the cable in a location that will place the splice in a protected area in the vessel. It should not be exposed to rain or spray, nor be allowed to lay in the Bilge or other area which will allow it to be submerged in water. If using a heat shrink insulating material, for either the center conductor connection, shield connection, overall splice, or all of the above, place over the cut ends now.<br /><br />Carefully strip approximately 1 of the outer insulation or jacket from the ends to be spliced. Unwrap the shield and twist it as shown below. <br /><br /> <br />Strip approximately 3/8 of the inner insulation (center conductor) from each end to be spliced. <br />Twist the center conductors of the two ends together, then solder the connection. Use special care to allow full flow of solder without damaging or melting the insulator around the center conductors. This can result in a shorted connection and damage to the sounder. Wrap the solder joint in good quality electrical tape or heat shrink as appropriate. <br /><br /> <br />Twist the shield wires together and solder this connection. Wrap a small piece of Aluminum Foil over the entire splice. Make certain the foil makes a good contact with the shield wires to prevent, reduce, or eliminate electrical noise or interference. <br /><br /> <br />Finally wrap the entire splice with electrical tape or use the Heat shrink material previously installed to completely seal and insulate the splice connection. The transducer is now ready to use. <br /><br />If we can be of any further assistance please contact us. <br /><br />Lowrance Customer Service <br />12000 E. Skelly Dr. <br />Tulsa, OK 74128 <br /><br />Customer Service: 1-800-324-1356
