Welcome Guest - Sign Up today
No announcement yet.
Crimping fuse holder
  • Crimping fuse holder
    The old fuse holder had a 4 way crimp.
    Should I use Buchanan C-24 crimpers...
    to crimp these?
    If you distort the tube, it wont fit in the housing. I have a Kline crimper tool and a ratchet crimper like the ones below.
    1990 Steiger Craft Chesapeake 23(pilot house)
    1974 28' floating pontoon dock
    1968 Sportcraft C-Gull
    Re: Crimping fuse holder
    Ayuh,.... Better yet, go to a fuse block, 'n get rid of yer in-line fuses altogether,...
    • #3
      More good advise from Bondo.
      I rewired much of my boat this winter and discovered 8 inline fuses located from "difficult to access" to "impossible to access". Simple result of adding stuff over the years and in too much of a hurry to get back out fishing. After the rewire using fuse blocks (2), I now have a standard fuse type and location should I need to replace one. It's worth the effort.
      • #4
        No, this is for the dual battery switch location at the rear of the boat for accessory feeds. I have 4 fuse blocks and multiple terminal strips at the helm. This is how the boat was wired to begin with.
        • #5
          Oh, I just found these weatherpack crimpers...
          • #6
            Got her all crimped with the Delphi crimpers(last pair), worked perfectly.
            • #7
              I had trouble with those type of fuse holders, where they grip the fuse gets loose , on my VHF radios when transmitting, it was too much load for that type of connection. The radios worked fine on receive but wouldn't transmit. This didn't happen all the time but once is enough.
              36' x 12.5 ' Aluminum, Built by All American Marine, 1989, twin Volvo Penta AQAD41A , DP-A out drives
              Furuno 1623 Radar, (2X) Standard Horizon Matrix VHF radios , Si-Tex Color Max 11" plotter with black box fish finder. Furuno LS4100 depth finder. ZF Mathers Micro Commander Controls.
              Propex HS2800 propane forced air cabin heater.
              • #8
                I hate those fuse holders with a passion.
                http://www.amazon.com/Ancor-607019-E...ne+fuse+holder
                is what i would use.
                1998 Wellcraft Eclipse 24 Cuddy
                Volvo Penta Duo-Prop 7.4L "LK"
                2006 Sun Tracker Party Barge 21
                Mercury 90 4-Stroke FI
                "Common sense is not very common"
                "Failing to prepare is preparing to fail." -- John Wooden
                • #9
                  I like those much better Bruce. I appreciate the heads up K-2. I already installed them . If I have any issues, I'll swap them out ASAP.
                  • #10
                    You guys were right. Those yellow fuse holders are a total hack. I replaced them with a better product. But once again, there's a limited option for 10 gauge wiring, and no option for crimping them yourself. So now I have an extra splice in an otherwise uninterrupted accessory wire run.
                    • #11
                      If you are doing this in a run to an accessory fuse panel, I typically put in a breaker which has threaded posts.
                      • #12
                        Thanks Bruce. You're probably right once again and my next post will be about adding breakers lol. The location is a wet one. Even the battery switch went bad. Condensation, etc. I'll have to work that issue out.
                        • #13
                          This is what I just put in on my pontoon to drive the fuse panel.
                          Circuit Breaker Waterproof 30 Amp CB185-30 Bussman - Amazon.com
