Welcome Guest - Sign Up today
No announcement yet.
Need a very simple wiring diagram for navagation lights.
  • Need a very simple wiring diagram for navagation lights.
    I Need a very very simple wiring diagram for navagation lights. Mounting the red and green on seperate sides of a center console and the anchor light in the back, thanx.
    Paddle faster Bubba, I think I hear banjos getting louder and closer!!!
    Re: Need a very simple wiring diagram for navagation lights.
    http://forums.iboats.com/showthread....=1#post2745677
    Don S.
    Please, no PM's (Private Messages) regarding boat/engine problems.
    That is what the forums are for.
    Only forum/moderator issues will be answered in PM's.
    • #3
      Hmm, may want to make sure that red and green mounted on your center console meets all the visibility requirements:
      http://www.boatsafe.com/nauticalknowhow/sidelights.htm
      Especially the part where they are visible x degrees above and below horizontal.
      San Diego, CA "The 619"
      2000 Sea Hunt Triton 172 CC, 2014 Mercury OptiMax 125
      "It's always easier to ask forgiveness than permission" -Colin Powell, et.al.
      • #4
        These are the navagation lights I will be using. I had used these same on another boat I had built about 4 years ago I had bought off Ebay.
        The navagation lights diagram drawing I found in my files, I had used on same boat, just could not remember where it was until now. I used a pull pull switch.
        Thanx for yalls help again, good fishin.
        • #5
          Originally posted by Baytown.boy View Post
          ...The navagation lights diagram drawing I found in my files....
          That is a nice drawing of rectangles and lines with random colors used, but it is not an electrical drawing that makes any sense.
          • #6
            What do you see wrong with it?, and then make corrections that are needed and post please.
            The switch is a pull pull type with three terminals. Pull once and the anchor/white light comes on, and pull again and the red and green console lights come on, and the white/anchor light also stays on.
            Let me know so I can correct it before I run my wires tomorrow.
            • #7
              You run the negative leads from all the lights to the battery negative (or the negative buss under the console); the positive side for all lights goes through the switch. Same concept as in the top diagram in the thread that was linked By Don.
              Bob, Seneca Lake NY
              '88 Bayliner 1700 Capri bowrider, 85 HP Force O/B, "Sea Weasel"
              '94 Grumman Fish'N Fun pontoon, 40 HP Merc
              Want a vessel safety check? Click here. Want to join the Coast Guard Auxiliary? Click here.
              Disclaimer: Although I am a member of the USCG Auxiliary, the opinions and advice in my replies are my own and do not necessarily reflect CG or CG Auxiliary policy or regulations unless so specified.
              • #8
                There are four problems with the diagram. 1) A switch should not have a negative liine connected to it. Negative lines go to ground (wherever you find it -- that's not on the switch) 2) the diagram does not show "where" on the switch each wire goes. Push-pull nav light switches, just like the three, six, and seven terminal toggle or rocker switches, must be wired correctly. Your diagram does not show that. 3) Your use of red and black wires is incorrect. Red is the positive feed. Only one red wire should exit the battery (or preferably the fuse panel) INTO the switch. The red wires TO the lights runs FROM the switch TO the lights. Grounds (black wires) FROM the lights connects to a ground buss or the negative terminal of the battery. 4) You show a red line going from the battery directly to the stern light and also to the switch. Wrong! The positive line for any light comes from the switch, not directly from the battery (unless you happen to want the light on all the time).
                • #9
                  Ok, yes I know yall think I'm a big dummy, but I think with yalls help, I got it figured out in my mind and on paper, see diagram below, thanx again for all yalls help. Let me know if I'm wrong. The last diagram was the one I had that was wrong 4 years ago and had to change it up also.
                  • #10
                    To use a push/pull switch, you are going to need the right kind of switch, several look the same on the outside, but work differently inside.
                    You need an Off- On circuit 1 - On circuit 1 and 2.
                    Circuit 1 will be your anchor light, and circuit 2 will be your bow/side lights.
                    My drawing may be off as to which terminal on the switch is actually battery, 1 and 2, as they change from manufacturer to manufacturer, just look at the instructions that come with the switch you get. Here are a couple from iboats http://www.iboats.com/Sierra-Push-Pu...-view_id.47136
                    Don S.
                    • #11
                      http://continuouswave.com/whaler/ref...ghtSwitch.html
                      • #12
                        Don S.
                        I already have the switch, just got my wires were crossed!! I was looking at an old diagram that was wrong. 4 years ago, and is still wrong. LOL
                        All is working right now. I had a tiller motor, and now have installed a center console and steering and the boat mechanic drilled a 2" hole from the back and into the front of the rear seat filled with foam for a wiring tunnel and put in a piece of PVC pipe, and run all the cables thru to the console. Now running the bilge pump and white anchor light wires into the tunnel so I can hook them up. That is all the wires in the tunnel now. All lights, GPS, dept finder, bilge pump will go thru a fuse panel under the console and switches will be on it also. All wires will be hooked onto the troll motor battery that is under the console now. Now just have to hook up the start/choke key switch and I'm fishing. Thanx for all yalls help, Doyle
                        • #13
                          Just to clarify --- Nobody said or even insinuated that you were a dummy. You asked for help and it was given.
                          • #14
                            I was laughing at myself for some dumb mistakes I make. I think the older I get, the less I know. I know I have C.R.S. disease now, LOL.
                            I used a wiring diagram that was given to me approx 4 years ago and it was wrong then and is still wrong now. Had in an old file , the only one and just printed it, tried it and it would not work, so I asked for yalls help. I do appreciate it very much. That file has been replaced by the right version. thanx, Doyle.
                            • #15
                              Where is the fuse??
