Re: Charging deep cycle batteries
I agree whole heartedly with BruceB. A 10 amp charge is really nothing for a marine or automotive style battery. Consider what the alternator would be charging a battery at. Most alternators now are rated at at-least 80 amps. Not saying that the alternator would be charging at that much, but if that alternator were charging a semi depleted battery, it would most likely be charging that battery at 20-30 amps while also supplying additional amperage for the load of the rest of the electrical needs.
Why I start a battery off at a 6-12 amp charge is very simple. If you needed to boil water, would you put your pot of water on the stove, and set it to low? Most likely not. Some people don't understand that when you're charging a battery, you're not somehow storing the voltage from the battery charger in the battery. What your effectively doing is creating a controlled boil inside the battery. When a battery gets depleted, the sulfuric acid and water start to separate, reducing the chemical reaction in the battery, which drops the available voltage/amperage. When you connect a battery charger to the battery, you create a small boil that mixes up the solution again. Thats why I start off at a higher amperage to get the battery going, then switch it down to a lower amperage to maintain the process once its going (kinda like turning the heat of the stove down to low once the water boils). Back from my trade school days, I remember my related teacher basically saying, if you could shake the heck out of a battery without damaging it, you could effectively charge the battery by remixing the electrolyte solution.
And again, back to what BruceB said, getting a good microprocessor controled battery charger takes all the guess work out of charging a battery.
