Txcatfish72
- Jul 4, 2008
- 2
I have a 2003 motor guide 43lb thrust trolling motor. Sunday it simply stopped working. All was going well and then nothing. After investigation I found that the inline glass fuse was broken. Since this time every fuse I put in it breaks. I have swapped out the fuse with a 40 amp circuit breaker, based on advise from my service shop. But it still pops after slowly spinning the prop for 4 seconds. The prop slowly spins and then I hear the pop. Is my trolling motor dead? Under the foot pedestal the connectors get really hot before the popping the switch. What should I do next? Any help would be much appreciated.
Thanks
TX
Thanks
TX
