Please Help,
I just aquired this boat (1987 Bayliner Capri 2.3L OMC Cobra) which needed a good washing. After powerwashing, including the engine, with Simple Green then water, I get no power to the fuse panel (Horn, Bilge, Nav Lights, Radio, etc.) The previous owner said those components worked before without anything else needing to be on.
The engine will crank/run and I have tilt. I followed the larger than other wires(Red w/ Blue Stripe) back to the engine which plugges into the big black connector. (Which I un-plugged and plugged back together.) The Large Black Ground also follows this path. I didn't see any fuses along the way. I did see a small/short male two-pin bootie connector (By the solenoids), but no female connector to plugg it into, thinking maybe I blasted apart.
Please let me know what you think before I snip and direct connect it ti the battery w/ an in-line fuse.
Thank You for your time and consideration,
OMC1987
OMC1987
