i have a 1982 Glastron SSV 167 that is wired for a bilge pump but has never had one installed. i bought the boat last fall and so far have not had any problems with water, just a small stream out the drain when i pull her out of the water but would like to install a pump to make myself feel better. there are no holes or through hull fittings or anything for the plumbing. trying to figure out the best and easiest way to install a pump and plumbing. any suggestions? thank you.
