Welcome Guest - Sign Up today
  • Dear Community Members,
    Over the last two years, there have been updates to the environment that have introduced challenges in usability, performance, and security. Efforts to improve the technology, user interface and site performance have revealed weaknesses in the platform and outdated software our site uses. This has made it increasingly difficult and frustrating to support and upgrade to more modern reliable standards that users deserve. This is not the experience we want for the members of this community.
    Members want a fast site that performs well across all devices, to be able to find relevant and interesting content, and easily share through text, images, video, and messaging on a secure platform. Our goal is to provide this user experience to all members. We will be updating to a new platform to better meet the needs of this community and allow us to provide support more efficiently. Our focus is to create a sustainable platform that performs well and loads faster on all devices while offering seamless ways to search and connect. Technology is constantly innovating - by creating an environment that we control we can maintain the site with more frequent improvements and maintenance updates.
    Although change can be difficult, we are here to support you through the process. We make every effort to review existing settings and make the changes needed so the migration goes smoothly. If you notice something doesn’t seem correct once the site goes live, don’t panic! We’ll have a dedicated person monitoring as the site goes live to answer any questions and provide support through this change. What’s next?
    When will this be happening? The plan is to put our current forums into maintenance mode (off line) at around 9am MST on 9/30/2020! The whole transition should take 24-36 hours. We recognize the user experience is slow and there are bugs from the outdated software. The sooner we can change that the better we can make the experience for you. You’ll start to see activity related to cleanup in preparation for migration very shortly. We will post an announcement to the community prior to starting the actual data migration.
    We appreciate each member’s contribution to this community and look forward to an improved experience for you all.
    - Management
No announcement yet.
2000 Bayliner Capri - 5.0 Mercruiser 5.0 Mercarb - Electrical Issues
  • 2000 Bayliner Capri - 5.0 Mercruiser 5.0 Mercarb - Electrical Issues
    Hello Everyone, its my first post on here but ill try to provide the most details to what's happening to me. Yesterday I recievied my boat back from the shop to have my compression issues fixed. We took the boat out and it ran like a dream for an hour and half. Afterwards we were on the back to the dock and first I felt a sudden drop in power, but things picked back up and we were cruising again. Shortly after everything turned off, and the 15amp fuse for the ignition blew. So I tried a few of them and they kept blowing so I went up to a 30 amp, the boat would crank but not start. Then I wondered if it was just out of gas even though the gauge showed a 1/4. We had the boat towed back and went to the store on the way home and filled it up. The next day, I tried troubleshooting to see If I could figure it out. I checked all the connections on top of the motor and could not find any that would cause it to blow a fuse. I did use the multimeter and determine that the plug for the fuel pump is only giving 7 volts and that the fuel pump will run the boat just fine when hooked up to an external power source. Should I just wire a relay for the fuel pump and drive it like it is, or should I keep searching for what's causing the issue? I tried to find the hidden 15amp fuse but could not find that. I also tried to find a fuse for the fuel pump relay but I don't believe I have one. My engine serial number is 0L619688, I have the Two barrel Marcarb also.
    15 amp ignition fuse blows and you install a 30 amp
    If your thinking the fuel pump has a fuse, it doe not
    When this was measured was the fuel pump connected, or disconnected and measured at the plug?
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 Seadoo GTX
    Merc Adults Only VP Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      I saw on a few posts there was a "hidden" 15 amp fuse somewhere behind the engine and that's what I was referencing. I disconnected the fuel pump and used the multimeter in the wire harness to measure the 7volts and that was while I was cranking the engine.
      • #4
        OK, this means there is something which is drawing to much current. The hidden fuse discussed in other threads are referencing the ignition fuse which yours is not hidden behind the helm
        If you still have the 30 amp fuse in where the 15 was I would change to no more then 20
        12V comes from the red/purple wire on the key switch thru the ignition fuse. From there it goes thru the key switch to the purple start wire or the Yellow/Red wire for starting.
        Disconnect things like the coil, gauges, alternator and then place the 15 amp back in place. Then connect one thing at a time until it blows
        07 Seadoo GTX
        • #5
          Do you have the wiring diagram? I tried searching but can't determine if its the right one for my boat or not! I mean for now could I hook the fuel pump to the ACC switch if I use a relay and fuse?
          • #6
            I think I have figured out the issue but just would like a second opinion on this as I don't want to waste the money on parts. I started to think what if I could run the fuel pump on the acc circuit so I ran the wire, and the fuse blew. Then I wondered if /I hooked it straight to the battery with a 30amp fuse by itself and a switch, the fuse blew again. The fuel pump did run on a battery charger so I thought it would run, but obviously not. Tonight I had someone crank it and the boat would crank with it unplugged but as soon as I plugged the fuel pump in, it would die. Would this make sense on blowing the ignition fuse if the fuel pump is bad?
            • #7
              The pump draws no more then 5 amps, it blew a 30 amp, so its bad
              This is a 4.3 but its the same as yours
              Click image for larger version
Name:	4_3L elect diag.jpg
              07 Seadoo GTX
              • #8
                Well I thought the problem was fixed. I bought a fuel pump for it, started right up and took it out on the lake and went for about 45 mins before that one died. This time though it didn't blow the fuse or anything so it would crank but it just wasn't getting any fuel, verified this at the house the next day. Then I went out today and bought a 300$ one from the boat shop that was quicksilver brand and it still will not get fuel to start. Would the next thing to change be the oil pressure switch?
                • #9
                  First verify the pump is running when motor is cranking.
                  If the pump runs then the pump is good and there is a clog somewhere.
                  Start with a gas can and length of gas line. Place the line in the can and see if you can get fuel to the carb.
                  If your able to get gas to carb then its either the pickup tube or the antisiphon valve
                  If your not able to get gas with a can then its clogged in another location
                  07 Seadoo GTX
                  • #10
                    I just ran a test on it, I unplugged the new Fuel pump and plugged the voltmeter in and I was getting the full 12 volts to the fuel pump when cranking. I then even hooked up a battery to the fuel pump and it ran perfect when it got the power from a battery charger? I feel like that test with it running on the other battery shows its not the fuel. I had a full tank when I went out on the water with it and was only out 45 minutes or so.
                    • #11
                      OK pump is running but its not moving fuel. The pump should be ok, need to find where the clog is
                      If there is no fuel at the pump then the pump won't pump it
                      07 Seadoo GTX
                      • #12
                        I agree, but I hooked a battery up to the terminals of the fuel pump and had it run separately then the engine and it started up just fine! I can't hear it running when connected to the battery harness and that's when I believe its not running.
                        • #13
                          This info changes things.
                          So now use a jumper across the oil pressure switch so pump runs when key is turned ON. This takes the oil switch out of the equation.
                          If motor runs without issues then its the switch or the electrical connections to/from the switch
                          07 Seadoo GTX
                          • #14
                            So place a wire connecting the two wires to the oil pressure switch? Port side near the rear and oil filter correct?
                            • #15
                              Yes, your switch should have 2 wires on it. You can pull it off the switch and jump the 2 wires together. Doing this will turn the pump ON when the key is turned ON and will keep it on when starting
                              07 Seadoo GTX
