Brycenwood
- Aug 3, 2020
- 4
I have a 2016 mastercraft nxt 20. It will start, but not with the key. I don’t really know what I’m doing and barely know anything about electrical haha but I’m trying to figure it out as I go. I just put a new starter and starter solenoid on. The safety neutral switch is getting 12vs and is working. I tested the starter relay switch and it’s fine. Im only getting 4.6 volts from the red wire that goes from the relay switch to the solenoid. (That needs to be 12 right?) I think it’s because I’m only getting 4.6 volts from the yellow/red wire that goes from the relay switch to the push button at the front of the boat. Does that need to be 12 volts? Any help would be greatly appreciated. I’ve tried testing the voltage at all of the connections that the yellow/red start wire goes through but I’m getting readings all over the place. Thanks in advance!
