It appears I have an aft bilge wiring issue. I took off the wires off the bilge pump now I cant figure out how to connect it.
Bilge pump has two wires labeled brown/red positive and black ground. There are three more wires from the bilge pump i assume this is the float switch two brown wires and one black wire.
On the boat side I have
Two yellow wires
Two brown wires that are spliced together , one brown/red and one brown wire... I cant figure out the connection. I keep looking at the 245 2003 bayliner manual and it doesnt make sence.anyone can help. Its Johnson bilge pump.here
Two yellow wires
