Welcome Guest - Sign Up today
No announcement yet.
Bildge pump wiring Bayliner 245
  • Bildge pump wiring Bayliner 245
    It appears I have an aft bilge wiring issue. I took off the wires off the bilge pump now I cant figure out how to connect it.
    Bilge pump has two wires labeled brown/red positive and black ground. There are three more wires from the bilge pump i assume this is the float switch two brown wires and one black wire.
    On the boat side I have
    Two yellow wires
    Two brown wires that are spliced together , one brown/red and one brown wire... I cant figure out the connection. I keep looking at the 245 2003 bayliner manual and it doesnt make sence.anyone can help. Its Johnson bilge pump.here
    More then likely its wired this way, and disregard the alarm if you don't have one
    Click image for larger version  Name:	Bilge pump auto.jpg Views:	3 Size:	56.3 KB ID:	10868692
    It could be this way but doubtful
    Click image for larger version  Name:	Bilge pump.gif Views:	2 Size:	3.5 KB ID:	10868693
    94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
    95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
    07 Seadoo GTX
    Merc Adults Only VP Adults Only
    G-Dad always said "First Liar doesn't stand a chance"
    • #3
      Im tring to match up the colors as it worked before i steped on it and the wires got dislogged now i cant figure it out. I have the wire diagram and picture of wires i just cant figure it out
      • #4
        Brown from 10 amp fuse to switch
        Brown other side of switch to bilge pump and float (splice)
        Brown/Red other side of float to 7 amp fuse (close to float or battery, should be in line fuse)
        Yellow other side of Bilge pump goes to ground
        07 Seadoo GTX
        • #5
          sorry im still having issues matching this up
          Boat side
          Yellow
          Yellow
          Brown(2 wires Spliced together)
          Brown Red
          Pump side
          Brown Red= Labeled +voltage
          Black= Labeled - Voltage
          Float switch
          BrowN wire
          Black Wire
          Brown Wire
          The way it worked before is i can control the pump via a switch at my helm. Also the Float switch would activate the pump. Any chance u can help me color code this back.. Ive been at this for 2 days and i hope i didnt make it worse.
          • #6
            Pic of wiring in boat...
            • #7
              the wires are so tightly packed toegtehre i cant see where they all go i can only see it at the connection thats why im having issues.
              • #8
                Would be easiest if you had a voltmeter but lets try, worst that could happen is we pop a couple fuses
                Pic in post 6 on the bottom I see 2 yellow, 1 black and what is the other wire color?
                07 Seadoo GTX
                • #9
                  These are the colors
                  Boat side
                  Yellow
                  Yellow
                  Brown Red
                  Pump side
                  Float switch
                  BrowN wire
                  Black Wire
                  Brown Wire
                  • #10
                    I'm looking at a pic and don't know which side is which. I'm going to assume that the wires with the marker on them comes from the pump and float side
                    07 Seadoo GTX
                    • #11
                      The float switch is just a switch, so one side of the switch has 2 brown wires and the other side has the black wire. It makes no difference which side goes where. The Brown/Red (boat side) can go to either a Brown or Black wire, so long as the Brown from the (2 spliced) goes to the other
                      07 Seadoo GTX
