Hello! I have a 1995 Mercury 200 2.5L XRi. Took it out in January and it ran great. Stored it out outside until recently and tried to tilt the motor up to move the boat, but the battery was dead. Used the manual override to lift the motor up just to move the boat, had the battery recharged, and now only the tilt/trim switch on the motor itself works. The tilt/trim switch on the throttle is unresponsive, the choke control from pushing the key in is unresponsive (I can't hear the normal 'click' from the solenoid' actuating), and nothing happens when I turn the key. It's like the entire control unit is not connected. Any thoughts what this might be? Currently trying to sell the boat, so hoping for a rapid repair!
Thank you,
EngineEar
Thank you,
EngineEar
