bleedblue94
- Oct 11, 2010
- 272
Motor is an 83 Johnson 175 upgraded to 35amp charging system
J175TXCTD
One motor, two batteries
So over the past 7 years I've gone through two of the water cooled regulators/rectifiers and it is becoming a frustrating issue to be wasting money. I am not sure if it is just parts crapping out of due to mistakes with people accidentally turning off the battery switch (which I know will toast the reg/rec).
It appears we lost one again now at the end of the season, so I want to change it out prior to storing the boat, but I also want to see if there is a way to prevent this from happening again going forward. Currently the switch is wired as follows:
1 switch - batt one
2 switch - batt two
comm - starter, all other panels, and electric draws
batt 1 - only wired to 1 switch
batt 2 - wired to 2 switch, has constant power hooked up for radio memory, backup bilge pump switch, amp for stereo
The hot line coming from the regulator is attached to the power wires on the battery side of the starter solenoid as was instructed on this site when I did the charging system upgrade. What I am wondering is if I leave everything as is, would there be an issue if I took that red wire from the reg/rec and disconnected it from the starter solenoid and ran a new wire directly to batt one?
This way I would never run the risk of the rec/reg being disconnected from a battery while the motor is running.
I we can still control which battery is feeding the general electronics of the boat, and we can charge batt 2 while underway by putting the switch to both.
Am I missing something here that would be a negative to doing this??
If I were to do this I assume I need to upgrade the size of the wire from the regulator to the battery since it is a 12'-15' run, would I just use a block to attach the reg/rec wire to a larger gauge wire to be run to batt one? I believe the idea should work, so my biggest concern is what gauge of wire do I need to use to ensure there is no melting or damage, and if that smaller wire coming off the rec/reg will be able to support a feed into a larger wire (although it already does that with feeding into the 4 gauge wire going from the comm switch to the starter solenoid).
Thanks
J175TXCTD
1 switch - batt one
2 switch - batt two
Thanks
