Switches and circuit breakers have a "line side" and a "load side". Line side is fed from the power source. Load side goes to whatever the switch or breaker is connected to. Bronze/gold is the LINE side. Silver is the LOAD side. If you are working with AC outlets, then bronze/gold is HOT and silver is neutral (call it ground if you wish). In DC circuits, when you are working ONLY with the +12 volt side of the circuit, there is no Positive and Negative. It is simply line and load. Think of the positive terminal of the battery as the LINE side of any circuit (because it is the "main line" so to speak). The negative terminal of the battery is simply "ground" and is not (or should not) ever be manually switched. There exceptions to that when dealing with sensors however where the sensor completes a ground path to turn on an idiot light or activate an alarm.
