Fishing up in Canada. When I was getting ready to leave the trim switch activated out of the blue 'up' and would not stop. Disconnected the battery, reconnected everything worked. Usually use the boat for two weeks in the fall. I'm guessing it's a relay issue. Wondering if I can just disconnect relay clean it up contacts. Or do you think I should get new relay.
