Boat started up and ran fine for a quick 5 minute trip, 30-45 minutes later completely dead when the key is turned. No gauges, doesn't even attempt to crank, but the trim still works.
I've read through a bunch of different threads on similar issues and I think I've got it narrowed down a bit, but hoping for some confirmation. Battery tests fine, boat is in neutral, no issue with safety switch.
I ran a wire from the battery to the ignition switch and got power to the gauges and can also hear the starter clicking, but still no attempt to crank.
I'm down to either the 90 amp fuse on the starter or the slave solenoid, based on my limited knowledge and testing. Any ideas as to whether it is more likely to be one of those than the other based on what happened with the hot wire? Should I just replace both and also, is there anything else I could be missing? I hate throwing parts at it, but nobody in my area can even think about looking at it for weeks, if they want to do it at all. Really need it running in the next few days if possible at all.
Thanks guys.
Thanks guys.
