Racklefrack
- Aug 6, 2017
- 44
I have a small 18' bowrider with minimal power needs -- standard stereo, VHF radio, charge phones and tablets once in a while, and -- of course -- starting the boat. I'm strongly considering swapping out my single starting battery for two deep cycle / starting combo batteries wired in parallel. My motor only needs 375 CCA's if memory serves, and a single deep cycle / starting combo battery has like 500 CCA's so two wired in parallel should be more than enough. Plus, with roughly 75Ah's of reserve x2 I could easily run my electronics without worrying about being able to start the boat at the end of the day.
I know it's popular to separate the batteries using a selector switch, but for my little boat with so little draw I just don't see the point. Two batteries wired in parallel to serve both starting and accessory needs sounds like the perfect solution.
Thoughts?
Thoughts?
