Shawn Williams
- Jul 3, 2019
- 3
I have recently purchased a 16' cape craft cc with a 96 48 spl.
Boat ran rough. I have rebuilt carbs, replaced power pack, replaced coil, plugs, reeds, and it was running pretty well.
I recently installed a garmin and wired it to an accessory switch.
Meanwhile I lost power to the ignition.
I went back through to see what had happend.
I had two sets of three wires to nothing. One with purple, white with brn line and black the other with purple, grey, and black.
Through reading this forum I see the grey, black and purple are for the tach.
When I power either purple I get an alarm the tach warning light flash in order and have power to the ignition. But the tack does not work correctly. I don't believe I'm getting power back to the battery I was left stuck with a dead one last week but that could be another issue I'm having with a sticking tilt button. Any help would be great. Also the tach has a harness to it with maybe 6-8 wires. So I'm unsure if the three with the purple grey and black are even needed? The boat starts and runs the tach is jumpy. But I'm powering the ignition from the accessories switch through the purple wire.
