In the attached, it appears that the yellow/red wire runs from the neutral safety switch to the starter relay. But the fuel pump relay comes off it too....is that run as a split or does it come after the starter relay somehow?
I'm trying to figure out how the pump retains power if its running off the yellow/red. That is only energized when actively starting, right?
