hello all,
I have a Johnson j70plsis 2001 70 hp 2 stroke that was hard to start, it turned out to be a no spark issue. It would start after long periods of cranking, after that it would stark immediately when the key was turned.
did some troubleshooting with cdi specs and turned out i had a bad stator.
replaced stator, timing based, spark plugs, plug wires, coils are all well per ohm readings, battery checked and good, new ignition switch.
I still have no spark, it is driving me nuts, I don’t know what to do. Help please!
thank you.
thank you.
