That is my plan...may just do the ACR since I really should never have a reason to combine. This is my current dilemma. I have one 4/0 awg wire that runs from the battery positive to the starter. From the starter there is a 6 awg wire that runs to the trim pump to a terminal that says: waring, post is connected to battery positive. From a harness a red line goes into wire wrap with the trim lines to the helm. Does the helm fuse panel (stereo, lights, bilge, blower)get its power from the trim pump? If not where is the positive of the helm fuse panel get its power? It's hard to tie all the wiring together because the starter is on the engine wiring schematic, the trim pump is on an outdrive wiring schematic, and the house wiring schematic I cant seem to locate for a 92 searay. Hoping someone has a similar experience.
Thanks in advance for the help!
