Dandydan
- Jul 27, 2018
- 34
I have a 302 Ford hooked up to a Volvo Penta 290 DP 1994 Sea Sport. I just recently successfully launched her after buying and installing a rebuilt long block. She ran like a top the first few times I got her out on the cold winter waters of the local lakes and sound. 3 times or so on the lake and then a couple of nice cruises on Puget Sound. Worked on getting the bugs out a little on every trip but I don’t recall any issues other than difficulties keeping it running at low speeds and having to turn up the idle and creating a scary thunk when going into gear. Then this weekend we took her out again and after idling through the long no wake zone, I proceeded to punch her up onto a plane. As the speed was building, she commenced backfiring. After readjusting the carb idle screw and the mixture jets back to what the book says is a good place to start, I tried to increase speed again and had the same backfire result.
This engine has not yet been broken in quite yet, has new plugs and wires, the carb was rebuilt by a very reputable carburetor guy, it has new fuel pump, and sea foam treated non ethanol gasoline. The intake manifold was machined when I put the whole thing back together. Like I said, it ran like a top until this week when something went awry.
My question is whether or not should be suspecting a electronic issue or fuel problem. I did not replace the distributor when I put the motor back together and would like opinions on HEI distributors and whether it would work on this motor. The current distributor is the type that has done away with breaker points, but I’m not sure I understand the HEI thing. Can you give me some insight?
