So everything seems to work fine when I have 2 batteries. If I move the switchs, bilge, lights, etc to the main battery everything works except the bilge float switch trips the fuse.
I have checked every connection at both ends. The only change I made recently was add a RPM gauge that shares a power lead at the purple line from the back of ignition for main power and there is a second power wire plugged into the light switch for a backlight. But everything seems right and works as long as they have 2 batteries.
Any ideas?
Any ideas?
