Welcome Guest - Sign Up today
Private Messages
We are aware of a current issue where your messages screen does not properly load and we are working on a fix.
In the interim, you can access you messages by navigating to this link: https://forums.iboats.com/privatemessage/notification
Apologies for the inconvenience.
See more
See less
Bow Switch Panel
  • Bow Switch Panel
    I have a 1991 Tracker Pro 17 and I need to replace this piece, but don't know what it's actually called. Can anyone help?
    Trolling Motor Recept., right here on I boats store
    https://www.iboats.com/shop/seadog-t...or-recept.html
    The last suit you wear won't need any pockets. You might as well spend it on a boat.
    • #3
      Thank you. I'm looking for the entire switch plate. Any ideas?
      • #4
        Sorry, I thought you just needed the plug. I would fabricate one myself, Check for a trophy shop or sign shop in your area. A simple job to drill a few holes and engrave the lettering. Be certain to take along the old one as a pattern. Plastic would give you a large range of colors or it could be done in metal.
        • #5
          I agree with dwco5051, any Laser Engraving trophy shop has the capability to make such a panel. And you can design that plate how you want if you want to change things around. I make my own because I have such equipment. I attached a picture of how mine looks. So any idea you like will work and you can even carry that design to the shop. Colors are near endless as well.
          Tom Boy Boat Project https://forums.iboats.com/forum/boat...s-what-trailer
          Rebuilt trailer project https://forums.iboats.com/forum/gener...r-back-to-life
          '76 40 HP Johnson rebuild https://forums.iboats.com/forum/engin...mplete-rebuild
          Minn Kota 599 Project https://forums.iboats.com/forum/boat-...ta-599-project
          • #6
            or contact your local tracker dealership
            you can also re-paint the panel you have and get decals for the letering.
            Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
            1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
            Past Boats
            1970 Wooster Hellion - Merc 9.8
            2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
            1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
            What’s behind you doesn’t matter.Enzo Ferrari
            • #7
              Thank you for your help.
