Welcome Guest - Sign Up today
No announcement yet.
Powering a 24V trolling motor from mains
  • Powering a 24V trolling motor from mains
    Hi all,
    This may be a bit of a strange request, but I want to power a 24V 100ft/lb (max amp draw 55A) trolling motor from mains rather than from batteries. I am experimenting 3d printed propeller designs for a university project, so the motor will only be used indoors.
    I could just use two 12V leisure batteries in series, but this seems pointless if I'm not going to take the motor out on water. I was thinking it might be cheaper just to run it from a power supply. Or would it be possible to power it directly from a 24V battery charger? If anyone has ever tried this, any tips would be greatly appreciated. Thanks!
    First things first. Welcome to iboats, we like new members...
    Your project sounds interesting for sure. It sounds like you are needing a heavy current power supply capable of supplying at least 55 amps. 65 would be a better choice to give you a little inrush current protection.
    Why you want to do is build one using a variable LM317 regulator. I say variable so you can test how the prop would work with a battery draining situation as well. However you will need a very large transformer to get that high of current outputs.
    You could gang a few transformers together to get that need, but then you equally have to use a lot of parelle power transistor to allow that current as well.
    Can that be done? Yes it can. But it is going to take some clever designs to get you there. Maybe a transformer out of a MIG or TIG or even a Stick welder would give you that transformer option. But then you need some heavy duty rectifiers as well. The LM317 is the heart of the circuit to control the power transistors. Could even use MOSFETs as well.
    I would think the two 12 volt trolling motor batteries would be the easier setup. Just keep them charged and it should be the easiest workable setup unless you want to build a high current 24 volt power supply. JMHO
    Tom Boy Boat Project https://forums.iboats.com/forum/boat...s-what-trailer
    Rebuilt trailer project https://forums.iboats.com/forum/gener...r-back-to-life
    '76 40 HP Johnson rebuild https://forums.iboats.com/forum/engin...mplete-rebuild
    Minn Kota 599 Project https://forums.iboats.com/forum/boat-...ta-599-project
    • #3
      Originally posted by george92 View Post
      Hi all,
      What is the planned duty cycle?
      Do you plan to run the motor constant for several hours or 1 to 2 hours and stop?
      If constant, build a 55 amp + power supply
      If for 1 or 2 hours then use bats and a smaller charger
      94 Formula 27PC Custom 509MPI MEFI3 , B3 XR
      95 Rinker 232 w/ 7.4L Carb 0F425011 B1 0F486471
      07 Seadoo GTX
      Merc Adults Only VP Adults Only
      G-Dad always said "First Liar doesn't stand a chance"
      • #4
        Yeah, 2-12v batteries with a charger to keep them up is the best bang for the buck. If you really want a power supply, a used HP Agilent/Keytech 6032A might do it for about $500.
        Mariah Shabah Z202 5.7L Mercruiser B3
        Jensen Marine 1972 Cal 21 cabin sloop
        Retired EE of 45 years
        • #5
          two batteries with a good charger is about half the cost as a 65 amp or more power supply with a bank of capacitors (you need a power supply with the capacitors for the in-rush current)
          the batteries and charger can also be scrounged up used if needed and your in it for only about $50
          Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
          1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
          Past Boats
          1970 Wooster Hellion - Merc 9.8
          2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
          1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
          What’s behind you doesn’t matter.Enzo Ferrari
