Currently have a 27 MHz radio and an AM/FM stereo receiver for music. The boat has two antenna bases - 27 MHz on the port side and AM/FM on the starboard.
I have the two antenna's to suit but am unable to identify which is which as the labels have faded beyond readable. There are some slight differences:
* the top antenna in the photographs is slightly taller than the other - by 30mm or so, they are around 180ish cm total length.
* the internal wire on the top antenna in the photograph is wound around with even spacing while the bottom antenna's wire is wound much tighter as it gets to the tip.
Are either of these indicators of being either the AM/FM or 27 MHz antenna?
I tried the local boating shop to look at replacements but they didn't have the same brand/model to compare. These seem to be Kingray < https://www.kingray.net.au/kr-au > who now seem to be selling GME branded products only.
