rdy2ride
- Jun 24, 2010
- 4
I have a 2005 Motorguide 24V 70lb motor that I think needs a new module. Are there troubleshooting techniques available to determine if module is bad or not? Also, I have only tried to run it on 12 Volt instead of the needed 24V for checking of the motor. Does the motor require 24V to actually work, or will 12V run it on a lower level of performance? Thinking that maybe the control panel will not function without 24V. Fixing to head out to shop now for a 24V test run. Any info appreciated.
