Welcome Guest - Sign Up today
No announcement yet.
new stereo head
  • new stereo head
    i am changing out the old, worn out (2005) sony for a newer model with bluetooth, i have been looking at the mex-xb120bt and the mex-m71bt both are sonys, my boat came with sony and has lasted up til last year, it still works but my kids would rather use bluetooth from their phones for music. the other reason for change is i installed an 8 channel amp but it has rca connections and stereo does not so i needed a line converter which didn't have a "how to tune it" so that's off and i have to shake it up every so often to get sound out...corrosion, any info would help me decide as to which one. thanks..
    Wow, for second there I thought you were going to say, "i installed an 8" tack tape system...
    Tom Boy Boat Project https://forums.iboats.com/forum/boat...s-what-trailer
    Rebuilt trailer project https://forums.iboats.com/forum/gener...r-back-to-life
    '76 40 HP Johnson rebuild https://forums.iboats.com/forum/engin...mplete-rebuild
    Minn Kota 599 Project https://forums.iboats.com/forum/boat-...ta-599-project
    • #3
      i do have one in a car though......
      • #4
        Looked at doing the same last Spring.was going to cost me upwards of $350 to duplicate the existing head unit with Bluetooth.
        Did a bunch of research and decided to give a standalone Bluetooth module a try.
        Works like a charm and saved myself $200 along the way
        i had pretty much decided in a Fusion RA70 before pursuing the standalone option.
        • #5
          The newest headunits are so massively packed with features, they are at a point of overkill. Do you have transom and helm remotes that you will need to swap out as well? You can pick up a headunit for a hundred buck that was made for bluetooth and streaming not just a model that has lightly included the ability to use bluetooth. Kenwood, for example, makes feature packed models with good stats when you compare alongside far more expensive models.
          2002 Chaparral 220 SSi
          350 MAG MPI
          Bravo 1
          2011 Yamaha FX Sho
          • #6
            my current head unit has an aux imput. a $5 bluetooth adapter to 3mm input works perfectly.
            Cheesehead boating the Gulf Coast of FLA 27.51° N, 82.53° W
            1988 Cruisers Rogue 2420 -VP 290 DP now powered by custom 468 - https://forums.iboats.com/forum/owner...988-rogue-2420
            Past Boats
            1970 Wooster Hellion - Merc 9.8
            2002 SeaRay 190BR - 5.0 - A1G2 - "Cheeseheads in Paradise"
            1984 Avanti 170DLI -3.0 stringer- "Ship Happens"
            What’s behind you doesn’t matter.Enzo Ferrari
            • #7
              And here all this time I thought a Bluetooth was a stage of tooth decay. Learn something new everyday.
              • #8
                thats black tooth
                Past Boats
                • #9
                  err...green teeth
