brzehentmaier
- Apr 12, 2015
- 12
Hello and thanks in advance. I have a 1995 Caravelle 175 open bow I/O 3.0 ltr mercruiser. About a month ago the fuel gauge would peg out intermediately. Was fine did not effect performance. Coil went bad and the marina changed it and adjusted the shift cables. Was ok a couple times out, now after you start it the alt gauge bottoms out, the fuel and oil pressure gauge peg and the blower motor light and the bilge light come on but the items aren't on. None of these things effect the running of the motor or the performance of the boat. After a little while of running it goes back to normal with no issues. At first when you turn it off and start it the issue goes away but then comes back until it seems like it warms up. Could this be a moisture issue? Where would all these items meet at the same place? Thanks again.Bernie
