Lou C
- Nov 10, 2002
- 11,847
This has been a more or less chronic problem on my '88 Four Winns with OMC I/O. The dash gauge will read low when I turn the key to the ignition position and the dash gauge reads 10-11 Volts. If I hook up a digital volt meter positive terminal to the ignition terminal on the switch and the other to the return terminal (ground) on the fuse box I get the same thing. However, when I hook up the volt meter pos terminal to the batt terminal on the ig switch, I get battery volts. It seems like I am losing voltage somewhere in the dash wiring, but I can't figure out how the current flows through the switch, gauges and dash accessories like the blower and bilge pump.
With the engine running the batteries read 14.3-14.4 V so its not an alt problem, it's a dash wiring problem. I looked in my OMC shop manual and the F/W dash wiring schematic. F/Ws way of wiring it different than OMCs (even though F/W was owned by OMC when this boat was built) and the F/W schematic is very difficult to read. It looks to me like there are several junction connectors where there could be corrosion but I am reluctant to try to pull these apart due to the age of the wiring and possibility of damaging the pins inside. The boat starts, runs but you can tell the dash wiring voltage is low because the blower runs slower than it used to. At first I thought it was just an old voltmeter with corrosion internally but as it turns out the old voltmeter is reading exactly the same as the digitial voltmeter when hooked up to the ignition terminal....with the engine running, the voltemeter reads about 2 volts low, vs what I have at the batteries.
Thoughts.....like where to start.....
In the past, I also had a no ignition issue that I traced to oxidation in the old fuse box and the old metal/glass fuses. I do have battery voltage at the fuse box though. I wish Painless Wiring made harnesses for boats like they do for muscle cars!
thanks for any suggestions.
