No Start 98 Yamaha 55 Hp 2 Cyc
Knottymate
Yamaha 703 Controls Manual Choke. Throttle Switch, Lanyard, Starter,Fuse Good.
Ignition Switch On gauges on Trim works. Move to Start Zero. Thinking Relay at engine
or Ignition Switch. Most likely what part and if possible part number. Any quick check with volt
meter to confirm. Regards Motor ran fine an hour later No Start.
Silvertip
You would have much better luck posting your question in the YAMAHA forum. This forum is for BOAT related electrical issues. Have you checked and cleaned the battery cable connections (both ends)?
