Hi, new to the forum but I've been lurking for a while looking for info. I have a 2007 Bayliner Discovery 195 with a mercrusie 3.0. The issue with the boat, When I go to turn it on nothing happens. There's no power to the dash, none of the gages are turning on, motor will not crank. It was cranking the day before but it wouldn't start because the battery was reading low, under 12v.
I changed the battery the next day making sure to put all wires back in place, now it wont start. I have checked all the fuses, the one behind the motor 15a, checked the 50a on the motor and the 90a on the starter. My ignition does not have a fuse connected to it (not one that I could find). I used a circuit tester and traced the positive wire from the battery to the starter, and its getting power.
I also tested the fuse box under the dash, all the fuses are working. There's a 8g wire connect to the fuse box, I test the wire and it also has power. I tested the ignition switch and there no power to it. I have the wire diagram and it shows the purple wire as being a positive wire, so should it be a constant power.
My question is what should I do next? could it be a bad lanyard switch, bad ignition switch or something I completely missed. This is my first boat so this is all very new to me. Thank you in advance for any help.
