I searched high and low and could not get an answer to the following. I have an '88 SunRunner 278 Classic with the old and unreliable V/P little square digital displays with the limits and signal converters built in. I have after trial and error discovered how to wire the sender to work with aftermarket gauges. The wires need to be wired as follows to make the V/P sender work with aftermarket gauges (Faria for Mercury/Volvo specifically) - White w/ Black stripe goes to a good clean ground, White w/ green stripe to sender terminal on gauge, White w/ red stripe optional for a stop (break ground) at about 1/4 lift on the drive (I opted not to use it for now but I plan to in the future using a small relay). You will need to adjust the sender a little bit but it works great. I hope this helps many in the future. I am an industrial controls technician and was confounded as to why it has been said by many this couldn't be done without a V/P control box (Black box).
