i was going to hook up a new battery switch i bought and it says to hook one terminal to the regulator to protect the alternator if the switch is accidently turned off while engine is running. it says use a battery isolator if the alt has an internal regulater. how would i know if my alt has an internal regulater? if it don't then where would the regulater be?
