Not realizing what’s been killing my battery till now. But if I leave ignition in run I can watch battery voltage off battery drop continuously. It just continues to drop by the the second ticking down. I haven’t let it drain past 8.5 or so volts but as so as I turn ignition back off the battery voltage starts rising at almost same pace it dropped maybe slower. Why is this happening? I can still operate boat but it appears if I accidentally leave ignition in run for even a full minute I’m probably not gonna be able to start it. Battery is fully charged and tested at Napa, which they said it was a good battery.
