Hello all,
I just bought this boat.
My electric ram motor was inspected and in normal working condition. When I put it in the boat shortly after hitting the up button without any load attached it pops the breaker. When I use direct power with my battery jumper it goes up and down with no hesitation , binding or heating of the wires going to the ram motor.
I don't know if it is the original ram that came with the boat 2002 Chaparral 35' or if it may have been replaced at sometime. I know if a fuse or breaker pops you shouldn't just use a larger breaker or fuse. But why does it pop without any weight?
Could it be the wiring from the switch, the breaker not the right amperage, the ram bad? I must be honest and am tempted on putting a larger breaker or direct power for a short while and keep an eye on it..... But I don't want to cause a fire by burning up a wire while it should have popped a breaker. Please advise.
Thanks,
Fred
Thanks,
Fred
