I have a 500 series Garmin gps that I disconnect and keep indoors when not in use. After a year or two of use, I'll plug it in and it won't turn on. What I found before is the female end of the connection gets some crap / corrosion built up causing the problem. The pins in that connection are very small. Does anyone know of a way to clean the female end of that connection? And then, how do you keep it clean?
Thanks for your help.
