NukeLaLoosh18
- Jul 22, 2018
- 6
Hi everyone, new to the board so forgive the noob if I'm in the wrong place. I have a 2000 Bayliner Capri 2050LX and none of the gauges work. Fuel, Oil Pressure, Water Temp and tach don't function (unsure of trim). I do however get a 'twitch' out of the fuel gauge when I go to 'ignition'. I've checked voltage and continuity from the barrel plug to the fuse panel even disconnected the 8G red and black wires and got solid 12v connected or not. I've run new 12G ground to the fuse block but nothing works. Short of taking it to a dealership are there any suggestions or ideas? Thanks in advance!!
