mikemlittle
- Jul 8, 2018
- 25
We were just given a 1989 Maxum with a 125hp Force Outboard. I was going to see if the motor worked before I put too much money into this project so I replaced the battery and ignition switch and the motor cranks. I tried to tilt the motor down so I could change the gear oil but nothing happens. In fact nothing else electrical seems to work other then cranking the motor and the Volt Meter. Most the fuses look ok but I'm not very familiar with how boat wiring works. Wiring on the battery looks a little wonky but maybe someone can help??
