devon.liljenquist
- Jul 3, 2017
- 14
Hi all,
This weekend I was on the water and I beached the boat, killed the engine and went to trim my motor all the way up. All of the sudden I had no power to any of my electronics. No blower, pump, lights, trim, horn. The only electronics that did work were my stereo and GPS. The stereo and GPS are wired directly to the battery. The others run through the starter somehow which I don’t understand. I tested the battery and have a full charge. Starter has 12.6 volts to it, but when I tested the smaller post near the positive terminal on the starter I got 0 volts. Picture attached. Also, I tested this relay that is near the starter and it shows 75 ohms when I touch the contacts. Isn’t that high? Picture of the relay attached.
I tested the resistance through the starter and it was less than one ohm.
Any advice on where to go next would be greatly appreciated.
