drdetroit3
- Apr 8, 2010
- 28
I have a 1995 Mercury 125, fishing the other day the motor started to trim up while off, I needed to disconnect the battery to stop, got back to launch reconnected the wire trimmed motor down and drove home. After a bit came out motor trim all the way up and did not stop had to disconnect the battery again then motor would not trim up?. Went to service they gave me a new up trim solenoid/relay, installed new part all worked fine, came back later motor was trimmed up and kept running, pump was very hot? Any ideas what it could be? trim switch at motor or console?
