There isn't any easy way to say it, so I'm just going to go for it.... That's a mess of wiring waiting to cause problems! Take this with a grain of salt and I'm trying to help get it cleaned up and working.
- I see black wires, butt connected to yellow wires that have a ring terminal on them, and then the yellow wire connected to the negative buss bar, wouldn't it have been easier to just put a ring terminal on the black wire?
- Using all one color of wire (yellow) is an accident waiting to happen, or at least use yellow for positive and black for negative, not + and - both yellow.
- Try to put a ring terminal directly on any wire if possible, cut out the butt connected jumper wires.
- I don't see a heavy 8 to 10ga wire feeding back to the battery, only small 14-16ga wires. If you pull a good load across that fuse panel it would/could melt your feed wire going back to the battery, while leaving all the fuses on the panel still functional. ***FIRE***
- flip your + input wire to the fuse panel 180* so it's not laying across the negative buss bar.
I would (and have done):
1- mount the fuse panel were it's going.
2- crimp ring terminals onto each wire with enough slack to reach the fuse panel, but not 2-5 feet of extra wire, maybe a couple extra inches in case you need to re-crimp.
3- fuse main 8-10ga + feed wire at battery and then connect batt wires to fuse panel
4- only black wires to the negative buss bar, then other colored wires to indicate the accessory on the positive side
Yeah, it's going to be a pain attaching all the wires to the fuse panel as you will most likely be laying down and reaching up to connect everything, but the finished product will be much better.
Hope this helps and good luck with your project!
