OUTBOARD ENGINE COVER CRACKED
dogtoy25
HI MY OUTBOARD ENGINE COVER IS CRACKED ON ONE CORNER FROM THE SUN,,, CAN ANYONE TELL ME THE PROPER ITEMS TO PURCHASE TO FILL THE CRACK IN, AND MAKE THE COVER LOOK NORMAL AGAIN??<br /><br />THANKS
D
DJ
Guest
Re: OUTBOARD ENGINE COVER CRACKED
dogtoy,<br /><br />You can use MarineTex to fill the cracked area.<br /><br />Then, just prime and paint. You can probably find the original color for the paint at:<br /><br />www.westmarine.com
Reel Appeal
You can also substitute auto body filler or auto glazing(if small crack).
crab bait
by all means,,, which ever substance you use,,, cut & wet-out a piece of fiberglass cloth & stick it to the inside/underneath of the crack/cover..<br /><br />buy some cloth where ever you buy the 'stuff'..
